Results 1 to 5 of 5
Thread: Drivers seat side airbag sensor on mk4 gti model and seatbelt
    Jun 2018
    Could some knowledgeable peoples help me solve my airbag fault issue these above listed parts have been identified as the fault these parts are prohibitively expensive genuine and new from vw ie sensor $ 275 can you confirm these are exclusive to gti only given lesser models don't have seat side airbags and any reasonable part purchase alternatives in Australia ie mechanical/water damage wreck. I need to get car off WOVR and mobile ASAP with all other works complete. Thks Mark
    Dec 2008
    Sydney/Canberra
    Have you tried bypassing the yellow connector under the seat?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2018
    Would this not disable sensor thou-car is in workshop so they would do such things
    Dec 2008
    Sydney/Canberra
    No, they just remove the connector from the harness and join the wires.
    The connector is known to cause high resistance in the circuit, which in turn logs fault codes.
    '01 Beetle 2.0
    Jul 2007
    Brissy
    Seat belt buckle has a sensor in it check that wiring too.
    Set belt chime will sound even when belt is on, is a good indication of a fault.
    This is related to airbag system - the air bags will only fire when the seat belt is bucked.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
