MKIV R32 with the following mods:
* Fully custom DMS or Moton suspension ($15k)
* Full poly bushings throughout suspension ($500)
* Fully adjustable, lighter, stronger suspension arms throughout ($5k)
* Smaller steering wheel ($500)
* Full moly welded-in roll cage (a proper one, not some pansy cage with one single door bar). Bars to come through firewall to strut towers. ($15k)
* 100L Fuel cell ($3k)
* ITBs ($4k)
* Stand alone engine management ($5k)
* Race duration cams ($3k)
* Custom valve springs ($1k)
* Ti rods ($3k)
* ARP rod bolts ($500)
* Custom pistons to raise compression to 14:1 ($2k)
* Knife-edged crank ($700)
* Headwork (port, polish, larger valves) ($2000)
* Dry sump ($3000)
* External oil cooler ($1000)
* Larger radiator ($1500)
* Custom TI headers and exhaust ($8000)
* Lightweight battery ($300)
* C16 race fuel
* Sequential gearbox ($20k)
* Full carbon body ($30k)
* Polycarbonate windows ($1k)
* Carbon race seats ($5k)
* LWFW ($1500)
* Race clutch ($2k)
* Cryo-treated gears ($2k)
* Orange haldex controller ($2k)
* BBK, carbon ceramic ($12k)
* All sound deadening removed ($1000, labour cost)
* Remove stereo, rear seats, all excess weight ($1000 labour cost)
* Lightweight wheels, R compond tyres ($8000)
* Skid plate ($1000)
* Pen (priceless)
* Lightweight interior door panels with pull straps ($500)
* Full lightweight aviation spec wiring harness ($3k)
* Complete fire suppression system ($2k)
* Peloquins front and rear ($5k)
* Every bolt throughout car replaced with lightweight equivalent, all safety wired ($3k)
* Remove all airconditioning and ventilation system components ($500 labour cost)
* Shorter ratio steering rack ($1500)
* 50 channel telemetry system ($15k)
* Power steering cooler ($800)
* Airjacks
* Centrelock hub conversion
etc etc... you get the idea...
