Results 1 to 10 of 32
Thread: The drama continues.....
    Cache Guest
    Hi Guys,
    I truely cant believe the run I have had with this car, as soon as it is fixed it will most likely go for sale. I know I cant speak for the other MK4 owners out there, but the frustration and drama that comes with owning such a mechanically idiotic car is astounding. This thing has taken atleast 5 years off my life expectancy.
    The story so far......
    Purchased car.
    Broken passenger side window motor, full motor and window replacement.
    Broken power steering
    Broken cup holder
    Shorted out internal electrics, no indoor car lights
    Broken front windscreen (I know not a car problem - rock)
    Car going into limp mode, found terrible bleed valve which was causing limp mode.
    Installed exhaust
    Exhaust backfiring, spoke to 2 mechanics, all think its due to excess fuel
    New plugs and various other engine internals needed
    Installed GFB DV
    Car running on 3 cyls (it seems), the sound of the exhaust sounds like a lawnmower and does not accelerate properly, feels terrible.
    Removed DV - mechanic said this was the problem
    Car running fine, still backfiring.
    Driving up the hill - car becomes chuggy again (See problem with DV) and fails to run properly. drives around like a deep sounding lawnmower, accels slowly but sometimes brakes through and boosts up ok.
    Took the car to my mechanic and he can not figure out the problem, we put it on the VAGCOM, no errors. Took it to VW, they cannot identify the problem, again the car was put on VAGCOM.
    I quote "There is nothing wrong with it accept for the fact that its stuffed and we have no idea why".
    For sale, 1999 MK4 GTI.
    gpk_gti Guest
    its your exhaust,,,, no back pressure id say.return the car to standard as much as possible.then begin from there... its not a jap car to have a straight through exhaust.Id be visiting Guy Harding up there!!!!!!
    Sep 2006
    Australia?
    For you to have shorten your internal electrics you have done something wrong maybe one of the mechanics did it?
    Isn't backfire normal?
    And for you break your glass and motor what did you do
    Feb 2007
    Toowoomba
    Maybe this shows the importance of having a car fully checked etc before you buy! (they would have atleast picked up on the bleed valve) and research yours mods!!!!!!!
    Cache Guest
    Quote Originally Posted by 91eah View Post
    Research my mods? I did the standard exhaust upgrade that has been performed on many many golfs before. I checked everything out on here and vw vortex before getting it done.
    In regards to an inspection, I had a RACQ 100 point inspection done....and that wasnt picked up.
    Jan 2007
    Coilpack?
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Cache Guest
    It cant be the exhaust, it's a standard 2.5' dump pimp, then a cat, then 2.75 pipe and a muffler. Thats a pretty standard system for these cars, its not straight through pipe.
    In regards to the glass.....the motor that drives your electric windows in the mk 4 broke, the arm the holds the window fell down and the window came with it. The window smashed inside my door (read cracked etc) and the motor was buggered.
    To go into more detail what the exact problem is:
    When I turn on the car it runs fine for a short period of time, then the exhaust note changes from a nice rumble to an uneven rotory/lawnmower deep off beat sound, when i accelerate like this the car does so extremely slowly and is really loud. occasionally the sound feels like it "breaks through" and the car runs normal, but then it happens again. if 2 full time VW mechanics and my performance mechanic cant figure out whats wrong with it, i really dont know where to go or what to do.
    I know I am venting my frustration here, but in my short but varied lifetime I have never had such a appauling piece of mechanic/engineering ever grace my eyes. 10 KG of potassium nitrate and some nitroglucerine should deal with it.
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    Come on guys, help this guy out......
    the explosives are only any good if you are fully comped
    Nov 2006
    Quote Originally Posted by Cache View Post
    Did they modify the O2 sensor or its position when they replaced the cat ?
    [See post above aswell]
    Cache Guest
    Quote Originally Posted by SoVeReIgN View Post
    Hmm....I dont know exactly what you mean. It was moved from the stock cat to the high flow cat, so I guess it was moved?
