Airbag Resistor Guide
You should shorten and then flatten the ends of the resistor tails a bit and then once installed cover the whole plug with some heat shrink to keep them secure. Try and get the resistor as close to the plug as possible rather than having really long tails on them.
I rewrote this guide above after sourcing the info from Vortex from various threads and have used this method in my car for a number of years now with no issues. I did it because I have disconnected all my airbags and completely removed them for rallying but it should work the same for the seat belt pyro charge/airbag connection.
Cheers Al
