Results 1 to 10 of 17
Thread: Door won't open, central locking & interior lights don't work
    Jun 2012
    G'Day ,
    I have recently purchased a '99 GTI Golf from the auctions. While the majority of the car (body and mechanicals) are in good condition, the electrics are presenting a few issues.
    The main issues are:
    Central locking doesn't work from the key and when locked from the drivers door window control panel, all doors lock and then unlock themselves straight away (don't stay locked).
    The interior lights work when switched on manually, but not in the door selection. The red lights on the door cards work at random.
    I'm guessing this is related to the door modules? From what I've read on the net there is a cracked solder problem for the central locking and maybe a stuffed microswitch for the interior light? I've had the fuse box out and all the connections and wiring look ok there.
    The other main problem is the rear L/H door doesn't open from the outside. It is opening from the inner handle ok. Will this be the outside handle cable tension being too high, or could it also be related to the door modules?
    Jan 2012
    I had this happen to Mr a few weeks ago. Check fuse 14 I think it is. It's located in you drivers door. Replaced it and everything worked
    Sent from my GT-I9100T using Tapatalk 2
    Jun 2012
    Was pretty stoked thinking that might work... but nope... I'm thinking it's the door modules with cracked solder.. Anyone else got a quick fix that doesn't involve me and a soldering iron
    Jul 2007
    Brissy
    The door handle pulls a cable, the cable attaches with a black plastic cli. I suspect this clip has come off. Pull the handle out and look into the gap to see if it is connected. Handle will have no resistance if cable is not connected. You maybe able to reconnect without removing anything.
    taligentx.com: Passat - Dlm 10 skinmounted...
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2012
    for the central locking. Can you roll the windows up with the key in the door lock? Have you tried slamming all the doors, front hood and rear hatch?
    Jun 2012
    Quote Originally Posted by skid plate View Post
    Thanks for the info, I'll try that tonight.
    Jun 2012
    Thanks for the link, good photo's there. I can't see the black clip with the door handle pulled out, so will start there.
    Jul 2009
    Geelong, Victoria
    Let us know how it goes
