Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Door won't open, central locking & interior lights don't work
    Small world, I am very familiar with ife on your 777s probably tells you who I work for. Have you been on board recently?
    Jun 2012
    Nice one! May catch you sometime
    Jul 2009
    Geelong, Victoria
    this issue is also similar as to when the body control module (also known as comfort control module ) has an issue,cany other internal items not working properly?
    also try fuses 13 and 14
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jun 2012
    Quote Originally Posted by Stan View Post
    Yeah, lots of internals not working.. including the interior lights, rear wiper is intermittent, mirror controller only adjusts RHS as well as the central locking. Will Google the BCM to see what it does...
    Is there a fix - or just replacement?
    Jul 2009
    Geelong, Victoria
    Dunno if the bcm (or comfort control module) can be fixed
    It lives up under the dash - you have to remove the plastic trim under the dash, and it is tucked up high, like instrument cluster high. It is held in by a couple of screws and has one or two cable bundles plugged into it.
    google and vortex are your friends.
    Your symptoms of various internal features not working are a pretty classic sign of this.
    this is for passat, but sounds like your woes:
    VW Passat Comfort Control Module harness repair | HeadFUZZ
    check for bad earths and water damage first
    They are not all that expensive on ebay (around $100), but get the right one.
    I also believe that a dealer can sort them out, no idea of cost (it's a dealer, so not cheap, I'm guessing....)
    Jun 2012
    Thanks for all the info, will take a look at the BCM when I have some spare time!
    Jul 2009
    Geelong, Victoria
    Let us know how it goes
