Small world, I am very familiar with ife on your 777s probably tells you who I work for. Have you been on board recently?
this issue is also similar as to when the body control module (also known as comfort control module ) has an issue,cany other internal items not working properly?
also try fuses 13 and 14
My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
Dunno if the bcm (or comfort control module) can be fixed
It lives up under the dash - you have to remove the plastic trim under the dash, and it is tucked up high, like instrument cluster high. It is held in by a couple of screws and has one or two cable bundles plugged into it.
google and vortex are your friends.
Your symptoms of various internal features not working are a pretty classic sign of this.
this is for passat, but sounds like your woes:
VW Passat Comfort Control Module harness repair | HeadFUZZ
check for bad earths and water damage first
They are not all that expensive on ebay (around $100), but get the right one.
I also believe that a dealer can sort them out, no idea of cost (it's a dealer, so not cheap, I'm guessing....)
Thanks for all the info, will take a look at the BCM when I have some spare time!
Let us know how it goes
