Results 11 to 20 of 23
Thread: Door locks
    Apr 2008
    That's a bummer that they're not interchangeable but at least I know now. Also, I just learnt that you can do all this without pulling the door trim off - nice!
    I'm going to attempt to pull apart my passenger door lock modules this weekend and resolder a couple of the connections that apparently crack.
    PS: did you know that you can just loosen the screws holding the windows if you're not removing them?
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    Quote Originally Posted by dubbed View Post
    Whats wrong with your module? I ask cause it just finally got mine working again after taking it out for the tenth time
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Apr 2008
    The passenger door locks sometimes pop up when I lock the car from the inside. There's a few tutorials on VW Vortex about how to remove the modules, dismantle and then fix. It's a fair bit of work but cheaper than the $450 I was quoted to have them fixed.
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    Haha yeah thats what i thought, Mine turned out to be the microswitch which was about a $10 fix. Its fairly simple to take apart just need to be wary of how things go and how they sit. Might need a 5mm bolt and nut aswell if your plastic holder brakes.
    Apr 2008
    It drives my girlfriend nuts when I keep pressing the lock button until they all stay down hahaha
    What parts did you need to replace and where did you get them? Did you have to drill out rivets and if so did you rivet them back in?
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    Heh, Not sure what that could be but does sound like the contacts compared to mine. My door wouldn't reconigse it was open or closed so the beeper for the lights didn't work and the door light didn't work either. Turns out the micro switch that tells weather its open or closed had lost its plunger. So i ordered some new micro switches that i got from rs components but vwvortex told me which ones. They weren't the right size but i could steal the plunger and other parts to make it work again.
    There is only one rivet which holds the plastic bracket on which temporarily holds the module onto the door card. Mine has broken but its not that big of a deal as the main bolts on the end hold it. You will need to drill out the rivet and either replace it or as i said use a 5mm bolt and nut. Probably easier to use a rivet if you have one. Theres only one as well.
    You can see the rivet on the right side in this picture taligentx.com: Passat - Dlm 15 screws
    Also this is a decent guide that you may want to look at.
    taligentx.com: Passat - Door Lock Mechanism Repair
    EDIT: Be VERY careful when taking the lock cylinder out. Unscrew it the very minimum otherwise it will fall out and forever be a pain in the ass.
    Apr 2008
    Thanks.
    Yeah it's definitely the contacts from what I have read. I've removed the door lock cylinders a couple of times and had no issues so fingers crossed I don't lose parts in the door next time I do it.
    My driver's door does the exact same thing re. the lights and not knowing if the door is open. How long did it take you to do and do you have details on the parts that I'd need?
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    I thought mine could have been the contacts aswell untill i pulled it apart and saw that there was a laquer coating over the circuit. Had a look and couldn't see anything wrong with the contacts. One of the pins had rusted however. So put that back then had a look to see if it wasn't something else. Pulled it all apart again and it turns out the plunger ****ed as i said before. I made up a temporary fit using the end of a rusted nail which worked for a week until it stopped. Found out that the "originial" switches were these, However they are a different size and on the wrong side. So instead i pulled the switch apart and pulled the plunger out of it and put it into the old switch. Mounted it back up and so far so good.
    The good thing is that if it is the 4th microswitch (seen here wire at the bottom and here you won't have to pull the entire thing apart.
    The whole thing took about 4hrs but thats taking my time and with a bit of experience in pulling the door apart, but it wont take that long. Most time was just waiting for glue to dry.
    I could never find out what the real switch is because all the part numbers relate to american sites which the Australian sites don't have. I guess you've read the vwvortex thread on them?
    Camden, Sydney
    Lots of confused people here.
    You are describing different problems.
    The original poster needs a lock eccentric, which wont be helped by tinkering with the door module.
    Lock eccentrics are easy to change on Mk3s, but a PITA on Mk4s. The parts should cost $50 or less, the $169 door lock will probably come without the bit you want.
    Good Luck.
    Dec 2008
    Sydney/Canberra
    I believe it does on MK4s, but definately not on MK3s.
    Went through the same trauma on a early 9N Polo once.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
