Results 1 to 2 of 2
Thread: Doing a major service.
    Ive got a golf 2001 mk4 2.0L 8v .Ok so I think I need to change: Oil, oil filter, spark plugs, air filter and brakes. Does this cover it also what are some good recommendations for these? thanks.
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by TurntableMonkey View Post
    Depends how far you want to go I guess, as you could also replace the
    cabin pollen filter, fuel filter, inspect timing belt, flush/ top up coolant, replace brake fluid/bleed brakes, check replace cracked hoses, replace gear box oil, check/replace control arm bushings ... What service is due by your vehicle log book? I think the Bentley Manual lists what to check at what mileage/ time interval.
