Results 1 to 5 of 5
Thread: Does the Bora 4Mo have rear upper shock mounts?
    Jun 2008
    Cronulla, NSW
    I ask the question because i can't find the matching part for the mk4 R32 (as i usually use that as a reference for suspension stuff on ECS as the USDM Bora was FWD.
    So, are these available for the 4Mo Bora cause i have a nasty rear suspension knock/rattle and it is driving me batty.
    Volkswagen Jetta IV VR6 24v > Suspension > OEM > Rear > ES#260801 Rear Upper Shock Mount - Priced Each - 1J0513353D
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Jun 2008
    Cronulla, NSW
    in fairness, these could have gone as well - but how can you tell what the heck is actually making the noise?
    Volkswagen R32 MKIV 3.2 > Suspension > OEM > Rear > ES#308015 Upper Spring Isolator - Priced Each - 1J0512149G
    I had the sway bar bushing checked (albeit a cursory glance) when i had some rubber changed.
    Jun 2008
    Cronulla, NSW
    anyone? someone's gotta know something here.
    Sep 2009
    Negative, our cars in the rear run a tube shock like seen here Volkswagen R32 MKIV 3.2 > Suspension > Shocks > ES#1831819 Sport Shock - Yellow (Rear) - 80-2818
    Thus the rubber mount/shock isolator is in the shock itself and it is attached to the chassis via a bolt that goes straight through each end.
    The spring isolators *could've* gone but the spring is held captive at full extension so i doubt it'd be wriggling around. Maybe check for loose bolts in the rear, loose exhaust hanger bolts, loose anything!
    Jun 2008
    Cronulla, NSW
    thanks dude. yeah, maybe not the spring isolators cause the sound is there on all kinds of bumps and road surfaces. Probably a dodgy install on my shocks (yes, from me sure, but they shocks were 800kms old when i got them so maybe a bad install or even part failure?). It is bugger me annoying though!!!
