I don't think 17s look too small but I'm an old fart![]()
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
17s are a little too small for the mk4 IMO. UNLESS they are ridiculously wide with a nice aggressive offset![]()
see thats what i was kinda thinkin.. needs dish and offset to pull of 17s.
these are 17x7 et40 so it'll only be 8mm wider than stock..
hmm
then i was thinking the s3 (17x7.5 et32) rims treza has would look schmick. wider offset.. hmm
Nah, you need a WIDE rim for the Mk4...
The wider the rim, the more tread you can get on them.
Here is a pic of 8.5 front 9.5 rear front et 44 rear et 38
uk-mkivs.net
yeh i reckon so.. i'll just do some saving up and get some nice 18's with nice offset
But then you end up with stretched tyres ...
http://www.vwwatercooled.org.au/f39/...out-46186.html
I don't get it, looks like you just fitted the wrong tyres!
Adam
2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
Previously -
2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
2002 Bora V5
Huh?
You dont have to stretch the tyres. Also, a little stretch is fine, I'm running 205/17/40's on a 7.5 rim, its well within the spec but still a little stretched. This seems to allow less flex in the sidewall and with a well matched offset, gives the widest stance which should give better cornering weight distribution.
Getting a wide wheel allows you to use wider tyres, some people like the stretched look, some to it so the wheel can sit wider while not having the tyre hit the wheel arch.
Right, sort of what I meant! If you have that much offset you end up having to have stretched tyres or they will rub. The golf pic you posted looks like it has quite stretched tyres.
Personally I would go for an offset that meant I could have the widest tyre possible on the wheel to give me the most rubber on the road and tyres sitting on the wheel in the shape they were designed to.
Adam
Previously -
2002 Bora V5
then it just looks wrong. I say NO to having MASSIVE tyres on a rim.
when i bought my first set of wheels, they had 225/45/17 and it made the wheel look CRAP
with a 205/40 they looked the biz, would have even put on a 185/45 just to make the wheel stand out more.
wide wheels with an agressive offset, a little stretch poke and tuck never hurt anyone![]()
