Results 11 to 20 of 26
Thread: Do 17" inch rims look to small?
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by GoLfMan View Post
    then it just looks wrong. I say NO to having MASSIVE tyres on a rim. Doesn't suit it one bit.
    wide wheels with an agressive offset, a little stretch poke and tuck never hurt anyone
    I didn't mean tyres wider than the rim, would like a 4x4 then! Just a vertical sidewall as the tyre was designed to run. If the profile is right then it looks fine.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Aug 2006
    Melbourne VIC
    I think 17's look good on a Mk4. It will handle and ride wheels too..
    Dec 2006
    Kilsyth, VIC
    Depends on the wheel really. It's a combination of wheel size, tyre size and height of the vehicle.
    I think for a Mk4 18" is about the sweet spot, but a good set of 17's can look magic.
    (I think for a Mk3 anything bigger than a 17" is hard to pull off, the sweet spot being 16/17")
    Quote Originally Posted by Rybky View Post
    Adam
    i get you now!
    I stil maintain it has to be the right set of 17's for them to look good on the mk4. Plus you have to have the appropriate lowz to pull it off too
    May 2010
    Perth
    need 18's
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    i think 17s are ok depending on the style, the stock bora 17s and wheels such as BBS RS look good (not just becuase i have them...) otherwise 18s you cant go wrong. depends on the colour and finish also, bright or machine finished seems to always look bigger in my mind
    Apr 2008
    On Sydney roads in particular, 18"s would be a PITA.
    The right 17s look fine. These for instance:
    And the Bora Sports look nice too:
    (Which I also happen to have a set of)...
    Nothing to see here...
    Mar 2009
    Wagga Wagga
    Manaz: They are R32 rims aren't they? May I ask how much you payed for them?
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by Manaz View Post
    And should you ever find yourself short of cash and need to offload them .... ME! ME! ME!!!
    Adam
    Previously -
    2002 Bora V5
    Adam
    there was a set on ebay the other day for $200!!!! but got withdrawn before then end...?
    another example WAS! Silver Dubs bora with the stock 17s
