I didn't mean tyres wider than the rim, would like a 4x4 then! Just a vertical sidewall as the tyre was designed to run. If the profile is right then it looks fine.
Adam
Printable View
I think 17's look good on a Mk4. It will handle and ride wheels too..
Depends on the wheel really. It's a combination of wheel size, tyre size and height of the vehicle.
I think for a Mk4 18" is about the sweet spot, but a good set of 17's can look magic.
(I think for a Mk3 anything bigger than a 17" is hard to pull off, the sweet spot being 16/17")
need 18's :D
i think 17s are ok depending on the style, the stock bora 17s and wheels such as BBS RS look good (not just becuase i have them...) otherwise 18s you cant go wrong. depends on the colour and finish also, bright or machine finished seems to always look bigger in my mind
On Sydney roads in particular, 18"s would be a PITA.
The right 17s look fine. These for instance:
http://www.vwwatercooled.com.au/foru...63045f_o-1.jpg
And the Bora Sports look nice too:
http://www.vwwatercooled.com.au/foru...595_00mg-1.jpg
(Which I also happen to have a set of)...
Manaz: They are R32 rims aren't they? May I ask how much you payed for them?
