Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: DIY external resistor fix for fan problem on a Bora
    Apr 2010
    Sydney,NSW
    Has anyone with a Bora done the DIY external resistor fix for their fans? If you have, where did you mount the resistors?
    The instructions are based on fitting to a golf and suggest putting the resistors on a plate mounted under the left headlight but looking at my Bora there does not seem to be any room to mount anything around there!
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Apr 2010
    Sydney,NSW
    OK so the Bora has the same mounting point available as the Golf, it confused me because the photo of the mounting point is taken from under the car pointing up, so the plate is mounted horizontally! I thought it was vertical.
    Hopefully getting the plate made up tomorrow and fitting on Sat.
    Adam
    Previously -
    2002 Bora V5
    Apr 2010
    Sydney,NSW
    Fix implemented and working well!
    One strange thing, I connector the first resistor to one of the fan (not sure which one), did not cut the red/white wire though, just spliced in to it. Tried the car and both fans were happily spinning at low speed! So I cut the red/white wire after the splice, no change, both still work. Now I was not sure whether to attach the second resistor or not! I thought while I was there and everything was in place I might we well, the first thing I did was connect up just the red/white wire on the second fan and cut it, did not connect the red/black so in theory that fan should not be working at all ..... but still both fans are working!! WTF??
    Anyway, completed the connections and still both fans now operate at low speed, have not seen them run at high speed yet, hopefully they can!
    So if anyone needs some help with this mod let me know, it is not too hard, took me about 2 hours which included drilling the mounting plate and getting it fitting correctly.
    Adam
    Previously -
    2002 Bora V5
    Adam
    I am trying to find the time to do this mod to my Bora
    I have the resistors but still need to arrange a plate
    who did you get to make the plate up? or did you do it yourself
    I also have removed the headlights buy couldnt figure out where the plate mounts. Is it under the drivers or passengers side headlight?
    Also whereabouts did you tap into the wiring. I can't see where the fan loom is.
    Thanks for you help
    Apr 2010
    Sydney,NSW
    I went to a local Aluminium fabrication place and they cut the plate out for me for $15, I just had to drill the holes. Note that one of the holes in the instructions is not in the correct place (or I measured it wrong!) plus I also changed the design slightly and had the top two corners cut off (where the outer holes are) as these holes were just to clear some bolts. Hope that makes sense!
    To do this you need to get the car up on ramps or on axle stands, remove the plastic engine guards from underneath and then lay down under the left headlight and look up, the mounting point is under the headlight and is horizontal. You won't see this from above or even if the headlight is removed. The wires you need are right down at the bottom left of the fans, really easy to see and get to from underneath.
    For mounting the plate I first put a bolt through the hole from above and then tightened on a nut with spring washer (or a nyloc nut would be better) so that I made a mounting stud, then I could just push the plate over the studs and add another nut and washer. There would be no way to access the back of the bolt to tighten it once the plate is in place otherwise.
    Are you following the instructions on the web page where there are photos and a technical drawing for the plate? Sorry don't have the link to hand. If you are then when you get the splash guards up and look up the photos will suddenly make a lot more sense!!
    Hope that helps, let me know if you are still not sure.
    Adam
    Previously -
    2002 Bora V5
    Mar 2010
    Lesmurdie
    if you dont mind me asking what problem does this fix?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    It fixes a extremely common problem where the internal resistors that control both fans low speed burn out. so you do only have high speed or off. this can result in the air con compressor failing (which is what I am most worried about) or it can cause the fuse to the fans to blow as it is only pulsing to high speed which draws a lot of current. this will mean no fans at all and a serious problem.
    This explains a lot Adam. i thought it was mounted from above not under the car. I will have another look. Thanks
    Apr 2010
    Sydney,NSW
    And the easy way to check your fans is to turn the car on, set the climate control down to LO so that the air con is on then go and have a look at the fans, they should both be running at low speed. If they are not running constantly but instead keep pulsing at high speed only then your low speed fan resistors are burnt out.
    Adam
    Previously -
    2002 Bora V5
    Mar 2010
    Lesmurdie
    Quote Originally Posted by Rybky View Post
    Adam
    hmm Crap i did that test today and they were either both on or both off. I had been running before but that shouldnt matter. So how do i got about fixing this?
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by Back Door Shenanigans. View Post
    With the aircon on both fans should be running at low speed so if they just kept coming on at high speed every 20 secs or so for a few secs then you have the issue.
    This is what I found, have a read of it all to understand the problem:
    FAN PROBLEM - POLL SYNOPSIS - uk-mkivs
    Then somewhere in that summary thread is the following link which is what I used:
    This fan repair modification was developed for a 2002 model V5 Golf, it will probably be OK for other Golf models especially the V6
    I modified the plate design slightly, just angled off the two top corners where the outer holes are, they are not used for fixing just for clearing existing bolts, so I figured while the plate was being cut they could just cut the corners off. Also the mounting hole bottom right is in the wrong place I think, or I measured it wrong! So check it on your car. For the wiring connections I used those splicing blocks, not sure what they are called, the ones where you don't have to cut the wire you are connecting to.
    Any questions let me know as I just did this recently.
    Adam
    Previously -
    2002 Bora V5
