Results 1 to 10 of 12
Thread: DIY: Broken Mirror Switch knob fix
    Jul 2007
    Brissy
    So I snapped off the knob for controlling the mirrors !!
    After looking around I came across a very odd listing on Ebay for VW Golf mirror control switch - mirror remote control button.
    WTF some plastic tube thingy that goes inside the switch.
    Well I bought it cause it was only 1 quid and 3.5 quid postage.
    Ebay seller NonStopAuto
    This is the little thing.
    Get the mirror switch out of the door.
    You need to take off the door card, a simple thing for any VW tinkerer.
    The pop the switch out by releasing the tabs and push.
    This vid covers it How to remove a Volkswagen Mirror Switch, Simple 10 minute job - YouTube
    Remove the broken piece from the knob.
    It looks like the clear plastic inside the knob is all 1 piece. I actually started to drill a hole in there. I tried to snap off more of the plastic rod so drilling would be easier. I gripped with pliers and it came out. Sweet.
    So you need to take the broken knob and hold it in a vice, get some pliers and grab the little bit of plastic sticking out. Grip well and pull like all hell.
    Here you have the broken bits and the new bit.
    Now pull apart the switch !
    Simply release the tabs and seperate the 2 halves, not much force required, pretty simple stuff.
    So one side has the electrics in it, there is a blue touch pad inside the hole.
    The other side houses the mechanical bits
    The piece sticking up is the plastic rod that has snapped. It has a spring loaded nib on the end which presses on the touch pad in the electrics side.
    We want to replace that plastic rod.
    So pull out the broken one, swap over the spring and nib, then pop in the new one. Put the switch back together.
    Almost done.
    Take note of the position of the switch, left / right / centre, line up the knob and push it on. It will make bit of a click once it is seated correctly.
    Go put it back in the car and adjust your mirrors like a pro.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2009
    Geelong, Victoria
    awesome tutorial thanks!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jul 2011
    South-East Brisbane, Queensland
    I would totally do this but when mine broke recently I was doing about 100km/h with the window open. That knob is never to be seen again.
    Dan!
    v5 Bora/Indigo Blue/Remus sports exhaust/JOM coilovers/Lots of DIY bits and Pieces/
    Jul 2014
    first post double post
    Jul 2014
    Thread necro but you can buy a whole knob from HK for $6 ish if you lost the knob. Just make sure you got a right handed one. Cheers.
    Quote Originally Posted by echineon View Post
    I've bought a few HK ones and the illumination is bad thanks to the type of led they use. I ended up unsoldering the leds off the original switch and putting on the HK one. Still not quite as good as genuine but close enough. Genuine ones usually have slightly better printing too. A bit pedantic but one of the HK ones I got was so much darker than all the other lighting I could barely see it.
    Oct 2013
    Eastern Melbourne
    Or just head to your local wreckers and pick one off either a MKIV VW or a Audi Passat of the same vintage
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
    Aug 2017
    Adelaide SA
    Quote Originally Posted by mikk View Post
    Can you tell me if the LH drive and RH drive mirror adjustment switches are interchangeable?
    Dec 2008
    Sydney/Canberra
    The markings for left and right are upside down.
    RHD switches aren't hard to find on Ebay. Last one I bought was about $15.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by Umai Naa!! View Post
    Yeah, easy to find. My last one cost me about $3.30 and the illumination was better than the switch I bought years prior to that which had prompted me to swap in the original LEDs. I used the latest switch without changing LEDs and it was fine, with lighting only very slightly different from the original but almost impossible to tell unless you're specifically trying to find the difference.
    The heated mirror switch with L "heated mirror" R will work in the place of an L 0 R switch and they're usually cheaper.
    i've also used a 4 position folding mirror switch in place of an L 0 R switch and it also worked. I have heard that the UK folding mirror switch and the Japanese folding mirror switch look the same but that there may be different variants at some point in time. Not sure of the details of this and I have not tested. I do also know that there are different ways the folding mirrors are wired up.
    Also I bought one switch and the seller accidentally sent me a LHD one instead of a RHD one. They part refunded but now I have a LHD switch I don't need that cost me next to nothing.
