Results 1 to 10 of 16
Thread: Diverter Valve options
    Aug 2007
    Camden, NSW
    Hi guys. The sound from my '03 GTI's DV has changed from the normal psssh sound to a flutter (like in this video), so I'm guessing the APR R1 DV has given up and needs replacing. I've done a bit of searching here and around the net for replacement options and was hoping I could get some opinions. My car has the APR K04 upgrade, along with 2.5" turbo back exhaust, Forge FMIC, BMC CDA being the main ones.
    Will an OEM 710N get the job done or are one of the after market DVs, such as GFB DV+, Forge 007 or 008 or another APR R1 a better option?
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    Oct 2009
    Mitchelton, Qld
    GFB DV+ all the way for me. Although I'm only Stage 1 but it ****s all over the OEM DV.
    Mar 2011
    Inner West, NSW
    Yep, agree with the GFB DV+ - Have one installed on my APR tuned 8L S3 and it is soooooooo much better than the stock pos. Plus they're local and the boys will help you should you run into any issues.
    If the DV is sealing and lifting under vacuum, there's nothing wrong with it. Mine flutters through the BMC CDA. It's an EVO one with a diaphragm like the APR.
    Test things before throwing them out, your wallet will thank you.
    Aug 2007
    Camden, NSW
    Had the car checked. Diverter valve faulter. I'll be picking up a GFB DV+
    95 MkIII VR6 (sold)
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by donweather View Post
    Any further information on this claim? What do you exactly mean?
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Sirocco20348 View Post
    The ability of the GFB to hold boost and then also regain boost post gear changes is much much better than the OEM DV. I don't have a boost gauge, other than the bum in seat boost gauge, but that's certainly what it feels like. Also seems to hold boost more/longer in the top end revs. Again only judging by the seat of the pants boost gauge.
    Aug 2007
    Camden, NSW
    Not lifetime warranty on the APR one, check that out.
    No lifetime warranty on the APR R1.
    95 MkIII VR6 (sold)
    Jan 2011
    Gold Coast, QLD
    I do know the feeling your talking about in regards to the regain of boost after changing gear. I noticed that with my forge copy I was running for a while. I thought it might have had something to do with the spring design. But I think the gfb valve is diaphragm still. Interesting to know.
