Results 1 to 10 of 20
Thread: Disc brake replacement
    Erskineville, NSW
    Quote Originally Posted by 4m0ti0n View Post
    Just a thought 'though, why is it bad for discs to get thinner? is it a heat issue or can ventilated discs could get weak if too thin?
    Think of the disc rotor as being a heat sink.
    • Less mass means less ability to absorb or dissipate heat.
    • Less structural integrity & increased heat increases likelihood of warping.
    • They can get thin enough that the brake pad can fall out of the guide slots in the caliper.
    • They can get thin enough that the piston will pop out of the caliper
    • More heat means increased likelihood of hotspots, cracks and ultimately, structural failure.
    Quote Originally Posted by D3bb4 View Post
    Bendix is the only non-OEM brand that doesn't void manufacturer warranty.
    That is definitely NOT true! Why is Bendix any different to any other aftermarket manufacturer? In fact, the exact ACCC ruling is:
    "If a part is non-genuine, but is interchangeable with the genuine parts, it could be seen as being fit or appropriate for the purpose and would therefore not void the manufacturer's warranty."
    How is that a Bendix only thing? Bendix pads would definitely be in the lower range of quality and performance vs. dollars...
