Originally Posted by
sdr
I was told after they had a look, that the discs were worn beyond minimum legal and would have to be replaced, along with a new set of pads. He showed me a new set of discs, compared with old, and they did look worn, but ok. Thing is, the car only has 60k on the clock, but was assured that this is standard with the Golf, and discs need replacing around the 60 - 70k mark.
What is the current thickness & what is the factory minimum? Allow about 1-2mm under your current thickness to machine down to a flat parallell surface. If that brings you under the minimum then you need new rotors. RDAs for the rear of my Mk3.5 were only $45 each at Auto1 in Carlton.
I'd be trying a specialist like Wolfsburg Motors (up near Newtown) or the one on Anzac Pde (near Centenial Park) - I don't know of any around St.George area.
I'd be looking at the upper spec Ferodo pads. EBC are stinky & Bendix are "old fashioned" (IMO).
