Results 1 to 10 of 10
Thread: difference with AGU and AWP turbo inlet hose
    gpk_gti Guest
    Anyone know the difference between the AVC - APH - AJQ - AGU - ATC and AWW - AWD - AWP - AUM - APP - AWU - AUQ turbo inlet Hose???
    Thinking of ordering a forge turbo inlet hose(actually I have just think ive ordered wrong one! !)
    http://www.forgemotorsport.com/conte...duct=FMGOLFIND
    thanks guys!!
    You need to get the one listed for your engine as VW moved the DV and some of the other connections about.
    GAvin
    Oct 2006
    sydney
    go to robbos for cooler clamps the standard ones are rubbish. My mates rs6 blow the pipes off three times before geting the robbos performance clamps, they look better, hold tension better and are cheap 3 dollars each.
    gpk_gti Guest
    so am I to understand that basically its the same just bits have been moved???
    Quote Originally Posted by gpk_gti
    Yeah and no. Later cars have additional and different sized takeoffs. You need to get the right one for your car.
    Oct 2006
    my 02 model is a AGU. just on the left side near the rad bottle you can see an imprint of what it is if im right..
    i just chucked my forge tip in yesterday actually, i advise if you dont know what your doing set aside a day for it. check vortex faq for instructions, much easier that way around.
    think will be bringing more Forge TIPs next month, along with other branded TIP's as well. 10-25% off rrp too.
    The engine code will be on the sticker in the service book or on the head I think, front left corner, you might have to take the cover off. If it has a cable throttle on drive by wire it's highly likely that it is an AGU.
    I don't think it's an all day job but certainly not a walk in the park either. Mine was a bitch to fit and even though it should have fitted the AGU it didn't fit perfectly and I had to do a bit of modification to the DV takeoff.
    gpk_gti Guest
    its a agu,,i know,,just ordered the wrong pipe(i hope not) thats all,will just have to wait and see.
    Oct 2006
    doesnt matter, you can just block off the extra hole.
    gpk_gti Guest
    thanks mate,,,thats what I wanted to know
