Results 11 to 20 of 28
Thread: Diff for 01 bora 4 mo
    Jun 2011
    Canberra
    Also, if the problem is a Haldex one option might be to import a used one from the UK where they are plentiful. When I was having diff issues I found an entire rear diff unit with the Haldex still bolted to it for sale for 200 pounds. Shipping would be a killer but a Haldex is a lot smaller than a diff, if you are willing to wait for one to be shipped over by boat it might not cost too much.
    If I ended up having to go down that route I was planning to see if I could find a volunteer from the UKMKIVs forum who would be willing to help me source and ship a diff in return for them keeping what ever parts came with the diff that I didn't need.
    Jun 2011
    O'Connor, ACT / Balmain, NSW
    hey djork,
    i did actually read that thread some time ago, and it seemed that quite a few people have the same problem. Can I ask where you found that diff unit ? Was it on Vortex forums ? 200 pounds (plus shipping + fitting) vs. $2600 is a no brainer.
    '01 Saab 9-3 S
    past rides: '01 Bora 4motion, '03 Golf Sport 2slow, '92 Ford Laser GL wagon (caught on fire)
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by governor22 View Post
    Definitely cheaper to get it from overseas if you can source one, but also note on top of that you have to pay for labour (8 hours) plus new haldex oil and filter. So perhaps add at least an extra $800-$1100 on top of the part depending on where you go.
    BTW did the mechanic scan you car for fault codes?
    VW Bora V6 4motion
    Jun 2011
    Canberra
    jpflorez, you need a new mechanic
    8 hours labour to fit a Haldex?!?!? When my diff went they pulled the diff, removed the Haldex, sent the diff off to be reconditioned, spent plenty of time chasing up the diff reconditioning guy (who does great work but is a bit of an unreliable diva when it comes to timing) reconnected the Haldex to the diff unit, did a filter and fluid change on the Haldex, refitted the whole lot and road tested it and it definitely wasn't anywhere near 8 hours labour.
    From what I understand (as usual feel free to correct me if I'm wrong, I'm used to it, I'm married) you can change a Haldex without even having to drop the subframe.
    The unit I saw for 200 pounds was advertised by a VW breaker on eBay.co.uk but I saw a few others on individual wreckers sites, I don't have any info anymore, I just went to google.co.uk and started searching (I used the UK Google so I could narrow down the search to UK sites only)
    There are currently quite a few listed on eBay.co.uk including the one I saw last month at 200 pounds. There is even one with diff, Haldex + subframe including axles and hubs for 350 pounds
    4motion diff | eBay
    Jun 2011
    OK - so i'll ask the guys to check for any error codes codes and then ask them if it could be the diff oil/fluid (supposedly lifetime guaranteed) or the Haldex fluid (every 60,000km).
    So far as i know, my bora doesn't whine at all (something my mechanic asked me). It just does the god-awful bunny hop thing in reverse/sharp turns.
    '01 Saab 9-3 S
    Apr 2011
    Ipswich, QLD
    Life time is the life of the manufacturers warrenty, this was 3 years or 100000km for mk4 VW's. Change your diff oil even if your diff is in perfect working order and it has never been done, any good 75w90 gear fluid will do the job and you need a fly sh** over a litre.
    2003 Bora 4Motion
    Jun 2011
    Canberra
    I reckon that if you have no whine and you have the bunny-hopping problem that it's haldex unit and not diff.
    If the diff (which is a purely mechanical part, no electronics or hydraulics at all) was messed up enough to bunny-hop like that wouldn't it be accompanied by some whine or pretty nasty crunching noises?
    Mar 2010
    Governor which mechanic are you using?
    Can I highly recommend you take your car to Canberra VW Centre in Belconnen? The guys there are very knowledgeable and have been nothing but a pleasure to deal.
    I suspect they will be able to diagnose your fault quickly for you, and provide a quote to fix the problem.
    Hope this helps
    Alex
    Jan 2007
    Quote Originally Posted by jpflorez View Post
    Got the same problem man (actually several people do) and it's most likely the diff. If the Haldex isn't serviced every 60,000km this usually happens. I rang up a mechanic who's done this twice before and to replace the diff with a second hand one, replace oil and filter, etc it cost $2600.
    You can keep running your car like this and it won't get any worse, just annoying and it'll chew your tyres a bit more. It may also put more stress on other parts but you just have to turn wider and quicker.
    That's more than I paid for a rear Peloquin diff from the states, landed and installed Someone is having a lend of you for a used one at that price.
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Jun 2011
    hey clark:
    yeah, I take it to CVWC in Belconnen, Deane and Peter pretty good. Taking it there tomorrow.
    '01 Saab 9-3 S
