Wat about a Gen 3 throttle body???
Iam looking into it tmorrow and new exhaust will be made....
Head work....wat dollars are they worth? has any R owners here done this yet?
I would say mill 3,4mm out/off the factory upper down pipes that bolt to the head-give it a good gasket match. And then the lower down pipes I have seen guys cut the flanges off and go with 2 true 2.25 mandrel bend pipes down to the cats. I think bmf still sells the 2nd half custom down pipes and i think usp does too. Or spend big bucks on headers!
SLAM.POKE.TUCK.DROP.DOPE!
thanks J nice stuff...
Extreme Exhaust has just done my car...No more flapper or that big tin can back to first muffler is all changed! i can only sai ...OMG... the .:R rumbles wat a difference
Just also looked at throttle body to adapt A Gen 3 mmmm..two will need to happen and i will stand corrected 1. after market ECU that runs a live by wire programme 2. and someone smart enough to set it up.
Headwork?
Read this:
http://www.cncheads.co.uk/vw_r32.html
I like this bit:
"Our gas flow measurements show that it has very good inlet flow but there was a lot of room for improvement on the exhaust side. After a challenging and extensive period on the flow bench we were able to raise the Inlet flow by 6% to 161.6 CFM. On the exhaust side we were able to make a huge increase of 30% to 129CF. This level of flow means this engine is capable of over 400BHP in normally aspirated form."
