Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 138
Thread: Development of our MK4 Rs for hps
  1. #21
    Jan 2008
    Canning Vale, Perth, WA
    dont forget that exhausts and tunes might not deliver a huge amount of extra power, but it may deliver it in an earlier way, and eliminate flat spots.
    A before and after dyno run will show that.
    Combining the exhaust/tune combo is likely to give a better result that the sum of the two individual scopes
    A tune will definitely make it spit and burble more!!
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
  2. #22
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Treza360 View Post
    On the MkIV they actually do a bit. The difference after I installed mine was quite noticeable. Not so much power wise (you're never really going to ever notice a few kw) but the ability of the engine to rev so much more eagerly.
    The other big difference at least in mine was the weight reduction. The stock exhaust pretty much requires two people to carry whereas the B&B/APR can be lifted easily by one.
    The MkV R32 i'm not so sure about. From what I've read I thought the extra 7kW or so it makes over the MkIV was down to different intake and exhaust design pretty much?
    Cheers,
    Trent
    Weight will be a factor with these cars Trent
    So alot of the debate comes back to the exhaust....Cats, Muffler etc.
  3. #23
    Feb 2009
    1 person can carry a mk5 exhaust quite easily, unless they are the biggest whimp.. so maybe it's a bit lighter but not that heavy (the milltek resonated is a bit heavier on the mk5 R32 setup)
    No idea sorry but good to get a dyno before/after as noise can be a bit deceiving and may sound like you're going fast. The headers are the one thing that do make a difference though.
  4. #24
    Nov 2007
    Coffs Harbour
    I know one thing.....the build of my exhaust wont be anything of the shelf
  5. #25
    Feb 2009
    Mk4's still sound a bit better for some reason..
  6. #26
    Mar 2008
    Have a read of the Motor mag tuner car review, Guy's 400hp Golf got a 6.2s 0-100 and the rennenhaus R32 got 6s. While in gear acceleration would be different again (in the GTIs favour), I think the exhaust sound and awd is still preferable for a daily driver. So even if it is slower, no worries with traction and you can just burble along at 3k shifts and still sound awesome. The hp search isn't really that bad, I'm sure the R32 would still go alright.
  7. #27
    Feb 2009
    Quote Originally Posted by VOLKSMAN View Post
    you'll get much better info if you talk to bug_racer who was part of the vw racing team.
    Just don't get a MK4 HPA turbo kit, that Silver MK4 that was in QLD ran like a dog apparently because of software problems (not saying the install was bad).
    Quote Originally Posted by AusScare View Post
    Yeah the R32 is a great daily driver with useable power and can put all of it down to the road. I like the torque and feels like you got nothing to prove but can step on it in any gear almost..
  8. #28
    Nov 2006
    Brisbane Qld
    Quote Originally Posted by G-rig View Post
    I wonder if those ricecans on the back had anything to do with that?
    I saw it up on a hoist at Sherrins once and the pipe from the cats was actually smaller than the stock R32 exhaust
  9. #29
    Feb 2009
    Quote Originally Posted by graeme86 View Post
    That's not the problem but yeah probably more to do with the ECU software not being right (the MK5 kit is a lot better apparently).
  10. #30
    Dec 2007
    Brisbane, Southside...
    The reason the software isn't right is because it isn't tuned properly for an Australian delivered R32 (no off the shelf software available). A better idea would've been to tune it here in Australia if someone had/has the software to do it (Custom Code?) or just put a piggy back system in.
    Anyway we're venturing off topic here.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
