Those are some pretty good gains, can the same be had on mk5? I should get the cams and already have headers!
Printable View
So it all goes back to you can go as fast as you pocket book it deep! If you guys like i can post when i find cheep deals most will be from the Us-Like a new HPA short runner went for 750 posted with new fuel rail also... APR 2.5" cat back Exhaust 650$ plus shipping--Im me for details if your interested and I can point you in the right direction and save some $$ Cheers J
I read on the German R32 forum that the Mk V does not have a forged crank like the Mk IV - thats the only place I have ever seen this mentioned so might be worth further investigation before you start pumping it up.
Seb, when you say V8 throttle body and MAF, can you advise which engine that was off?
What kind of rev limit/red line did the Motorsport versions have?
Cheers,
Trent
It was from an early s4 v8 I think , Im not sure , it was used cause thats the bolt pattern that was on the manifold .
Rev limit was 8000 rpm based upon the rules of procar at the time , it was later lowered to 7300 rpm
Thanks again Seb!
That engine still had a stock bottom end too didn't it?
Were the rod bearings changed at least to go to 8000?
