Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Dead turbo ??
    Aug 2007
    Ah sorry should read all the thread my bad Dont make the classic mistake of not checking the oil feed and return pipes, seen it before, and was in a dealership where a new hairdryer was fitted and seized soon after, the classic 1.8T carbon issue was the problem. Pipes were choked
    Jmac
    Alba European
    Aug 2009
    wonder how much it would be to fix something like that.. hmmm
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Sep 2008
    Townsville
    Yeah I did read in the bentley that it is important to "flush" the oil lines and the manufacturer of the new turbo suggest replacing them so thats on the top of the to do list.
    Quote Originally Posted by audi-tone View Post
    Hey I dont need the ATP manifold either so if you want both im sure 50 would cover postage (kinda heavy together)
    Sep 2008
    Townsville
    Well after a bit of a stuff around I finally got all the parts sorted...................
    New Vs Old
    The main difference I could see was the larger diameter of the compressor inlet.
    I already had an ATP manifold but the turbo came with another one which was ceramic coated and has clearance on the runners for removing some of the head ache installing them .
    All in all the instal was very straight forward EXCEPT for the TIP that the kit came with.
    The whole thing was just not right ! as in I had super massive issue with it reaching the maf as you really had to force it over to reach ,but then it would pull off the bottom and all the mounting points for the diverter ,PCV and other vacume points where in the wrong spot or wrong size so I had to ghetto mod a few things to get it back together .
    So with the fun I had with the tip I have ordered some stainless pipe and some silicon bends/reducers to make up my own tip in the hope of sorting out the mess of hoses around that area.
    Sep 2008
    Townsville
    Thought I would disassemble the old turbo to inspect the damage........
    When I first removed the hot side
    Inside the exhaust housing where it all got a bit touchie/feelie
    Most of the turbine wheel fell out when I started to disassemble
    Apr 2011
    Ipswich, QLD
    When it comes apart like that you know you were driving it properly :p
    2003 Bora 4Motion
    bit of araldite should patch it up
