Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Help on removing oil filter
    Feb 2013
    Hi,
    Just wondering if there was a special way to remove the oil filter as it seems impossible to remove by twisting it.
    Here's a photo
    Thanks for any input guys
    Apr 2006
    VW Race HQ - Sydney
    Multigrips .
    And the oil filter fitted is the wrong one !
    Bug_racer supports the rebellion of the euro revolution
    Feb 2013
    Quote Originally Posted by Bug_racer View Post
    Multigrips .
    Multigrips? Yeah this one was fitted on by the previous owner. Just got back from VW with an OEM oil filter but can't get this one off!
    Jun 2011
    Sydney NSW
    Quote Originally Posted by jeremyex_ View Post
    You need a "strap wrench". The strap wraps around the filter body and the handle then twists it off. Any auto accessory shop should have them. Best of all, you could ask if you could try is to see if it would fit.
    Now there is an "Irish" version, however it gets messy. Basically, you stab it with a screwdriver and get it off that way. It is a last resort, and sometimes, even that can have issues.
    Feb 2013
    Quote Originally Posted by wai View Post
    The strap wrench sounds good. Do you know if hardware places sell these? Etc. Bunnings?
    Thanks bud
    Dec 2008
    Sydney/Canberra
    Bunnings might, but Supercheap definately would.
    As Seb suggested, buy the biggest pair of multi-grips Supercheap sell. They'll get it off without much trouble.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Or pierce it sideways with a long bladed screwdriver and use the leverage to crack it.
    Aug 2011
    melbourne
    start going to the gym, nancy.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Jun 2008
    If you do this makesure
    You puncture through towards the end, away from the engine, use a posidrive/phillips head screwdriver.
    Punch right through and turn.
    Also when you put the new one on , put a thin film of oil around the sealing rubber ring before you screw on and tighten
    1993 MK1 CAB ! Work in Progress........
    Feb 2013
    Yeah it ain't coming off, bought a strap wrench and a tool that goes around the bottom of the oil filter that you can connect a ratchet to but it broke.. Gave up in the end. Have it booked in at Audvolks in a few weeks so it should be ok. Thanks for the input fellas, appreciate it!
