Could be the water pump impeller - sounds like classic symptoms of one that's dying/ broken, or coolant temp sensor. How long since you replaced it last?
So this one has me a little stumped. Just when I get the car running great this happens . Basically the water temp gauge randomly drops to 0, and then it'll go back up to 90, then randomly go back to 0. There doesn't seem to be a patern just completely random. Sometimes it won't do it at, all other times it'll do it like 5 times in a 20min trip. It doesn't seem to affect how the car runs, wideband shows afrs are the same as usual so I'm thinking it's just the signal that goes to the dash is getting interrupted. I have checked the wiring to the cts and it looks like fine. Has anybody had a coolant temp sensor fail like this or could it be my instrument cluster is dying??
Water pump was done when I rebuilt the engine about 4k ago, metal impeller too so that should be fine. Thermostat replaced at same time also. Cts is maybe 18 months old, so wouldn't expect it to go bad already, stranger things have happened though. Might order one and see if that's the problem?
I just replaced my Coolant Temp Sensor which was giving me dodgy readings - car was running rough and over-fueling
Is the temp sensor which signals ECU used to drive the dash gauge also, or is there another one ?
I know its a cheap pars but go check the electrical connector also.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Have a look in the electrical connector for the temp sensor as well. Sometimes the female terminals might need a little tweaking for a snug contact. You may also notice some blue corrosion on them as well.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
