Results 1 to 9 of 9
Thread: Dash temp gauge randomly drops
    Sep 2009
    brisbane
    So this one has me a little stumped. Just when I get the car running great this happens . Basically the water temp gauge randomly drops to 0, and then it'll go back up to 90, then randomly go back to 0. There doesn't seem to be a patern just completely random. Sometimes it won't do it at, all other times it'll do it like 5 times in a 20min trip. It doesn't seem to affect how the car runs, wideband shows afrs are the same as usual so I'm thinking it's just the signal that goes to the dash is getting interrupted. I have checked the wiring to the cts and it looks like fine. Has anybody had a coolant temp sensor fail like this or could it be my instrument cluster is dying??
    Nov 2006
    Largs Bay, S.A.
    Could be the water pump impeller - sounds like classic symptoms of one that's dying/ broken, or coolant temp sensor. How long since you replaced it last?
    Sep 2009
    brisbane
    Water pump was done when I rebuilt the engine about 4k ago, metal impeller too so that should be fine. Thermostat replaced at same time also. Cts is maybe 18 months old, so wouldn't expect it to go bad already, stranger things have happened though. Might order one and see if that's the problem?
    Nov 2006
    Largs Bay, S.A.
    I just replaced my Coolant Temp Sensor which was giving me dodgy readings - car was running rough and over-fueling
    Jun 2011
    Sydney NSW
    If the temperature is suddenly dropping to zero, it is more than likely to be a faulty temperature sensor. If it were anything else, the temperature drop would be a lot more gradual.
    One other thing is the wiring. A fault there (like a break in the conductor) would also give similar symptoms.
    Sep 2009
    brisbane
    Quote Originally Posted by wai View Post
    Yeah that's my thinking. Like the needle won't move around, it just goes bam, straight to zero then after like 2mins it shoots straight back up to 90. I guess I'll change the sensor and see what happens. But it's definitely not the cluster going right??
    Jul 2007
    Brissy
    Is the temp sensor which signals ECU used to drive the dash gauge also, or is there another one ?
    I know its a cheap pars but go check the electrical connector also.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2008
    Sydney/Canberra
    Have a look in the electrical connector for the temp sensor as well. Sometimes the female terminals might need a little tweaking for a snug contact. You may also notice some blue corrosion on them as well.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Lito View Post
    Well, it could be, but check the others out first as they are a lot cheaper. Somewhere there is an intermittent signal coming through.
