Results 1 to 4 of 4
Thread: dash led fading in heat
    Jul 2010
    Mitcham, Vic
    Hi again,
    I have noticed my LED read out on my dash that shows fuel ecconomy fades when it is hot weather. The fading starts at the top of the read-out making it hard to read this info.
    Any fixes or ideas?
    Cheers ...
    03 Bora 4Motion ... luv it
    Aug 2007
    Perth, Australia
    my display does the same thing. no idea why, maybe dry capacitors or something. I had a soarer with a digital dash and it used to turn off in the heat. THey fixed it by replacing some capacitors, but it could be a bit more complicated on a VW dash
    1991 BMW 318is RED E30
    Mar 2010
    Lesmurdie
    Same here, Also seems a bit dependent on light. Mine usually starts fading at 18degrees
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Mine to... Im over it after 3 years haha
    The outside temperature still works though... if you cant read it, it means its HOT
