Results 1 to 10 of 12
Thread: CV joints greasing.
    Mar 2010
    Lesmurdie
    CV joints greasing.
    Does anyone know how easy it is to grease the inner cv joints? I'm thinking by the look of it that i need a special tool to remove the outer clamps.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    May 2007
    Jimboomba. QLD
    Hi,
    If they are the same on the Bora as on the Golf, I believe that it is simply a 7mm allen key.
    Unless you have busted a CV boot or something similar that would cause the grease to escape....why do you need to grease them?
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Mar 2010
    Lesmurdie
    I thought they are this weird clip thing. The boots are fine its just flung the grease everywhere. I cant feel any inside.
    Sep 2009
    Then unless you've replaced the boot there's probably a split in it somewhere, they shouldn't normally spill any grease.
    Jul 2007
    Brissy
    The grease can't get out if the boot it in tact. If you have grease everywhere then the boot is probably torn.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2010
    Lesmurdie
    After having another look i can almost defiantly say that the boots are fine and that the clip isn't tight enough.
    Heres some pictures for proof.
    Passangers side.
    Drivers side
    So now i gotta go talk to joe about getting them repacked. Stupid clip required a special tool i think.
    May 2010
    bentleigh vic
    They do need a special tool and you can't reuse them. new ones come with the kit vw supply which is a new boot, grease and a clip they cost about $40 I know because I've just replaced mine. I used a special pair of vice grips which allowed me to get enough tension on the clamp
    Jun 2008
    Cronulla, NSW
    they are the stupid one-use clamps? I can't see the pics as i am at work, but in nearly every application of the clamps I am told that zip ties work just as fine or better.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Aug 2007
    Zip ties will only work if the boots are of the flexi rubber type, hard rubber or the VW Plastic ones will and do pop the boot back off. I agree these clamps are naff if not out on with the proper tool. Cant beat the original type clamps with again the right tool
    cheers
    Jmac
    Alba European
    May 2007
    Jimboomba. QLD
    Hi again,
    I used to work for a company called Driveline Services "www.driveline.com.au" who actually sell the proper bands and clamping tool....from memory (was a few years ago) the proper clips were worth cents each and the tool wasn't much either. Maybe give them a call, they now have branches pretty much all over oz.
