Is it manual ?
Try setting the speed when going fast. Then when going slower down hill hit resume and see what happens. If it works down hill it may be that your clutch is slipping and it gives up.
Is it manual ?
I have the exact same issue as the OP. I'll try the brake pedal test when I get a chance, but what needs to be done to actually fix the problem (assuming it is the brake pedal switch)?
2002 VW Bora 4motion Black
You head down to your local VW parts centre and buy a new switch for ~$20-$30, you then install the switch. Easy as pie. There's a nice how to guide on vortex for the brake light switch (not worth paying someone for an hours worth of labour for a 5-10min job).
http://forums.vwvortex.com/zerothread?id=1158315
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
The older switches you could stuff up big time, but most dealerships now stock the revised switch which is a up in and 1/4 turn, done.
Most Techs will charge around 1/2 hr to fit which they are more than entitled too.
Jmac
Alba European
this might sound a little crazy, but do you drive with your foot resting on the clutch? cos mine wont play ball unless im resting on the dead pedal....
just a thought!![]()
black mkIV .:R32 #001/200
04 black new beetle turbo
matt black 1970 beetle- low n slow!
My left foot never rests on the clutch pedal, either I'm actively using the clutch or it's on the foot rest. I've tried setting cruise speeds both with my foot on the accelerator and without, at various speeds, and various combinations of button pushing and holding, without luck.
Is it auto or maunal? If its manual the clutch pedal switch also mucks up the system, I have seen a few times the clutch pedal switch gone thinking that its in the depressed position cauing it to keep the cruise from setting as if you have the cruise set and working and press the clutch it turns the cruise off......VW..................
