clutch pedal switch? When the switch fails it goes into the "PRESSED" position, meaning cruise is cut out. easy way to tell is to bridge the 2 pins on the switch with it disconnected and the cruise should work ( might rev up between gears) drive it like this to see if the cruise stays on all the time or not
