check fuses #5 #15 #34.
Hi,
So today my cruise control has decided to stop working. Is there any common problems with it. Havn't checked the fuse yet forgot and am lazy. Happened after messing with the front bumper and installing resistor fix.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Yeah there all fine. Hopefully that reset something and it works will try soon
Brake switch is a common fault and will cause your cruise to not work. Check your rear brake lights come on when you press on the brakes. There's also a switch on the clutch and their may even be another switch on the brakes (can't remember). Normally though it's the brake switch. Only like $30 or so for a new one from VW parts (should have them in stock) and is easy to fix yourself. Have a search on VWVortex for stack of how to guides. If you get an older superseded switch there are some tricks to them or you can brake them in the same way that they fail.
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
So the brake switch works i assume as the brake lights work. Not sure about the clutch switch might get a multimeter on that sometime. The light is still on the dash
