Results 1 to 8 of 8
Thread: Courtesy Lighting Not Working
    Jun 2009
    melbourne, vic
    on my mk4 on the r/h/f door the courtsey light isnt working and i've switched the light assembly from the other door to the problem door and it has'nt solved the issue so then i started testing the wiring to see if had power to the light assembly which i found that i did but i dont know what else it could be maybe possible break in the wire im not to sure
    Jul 2009
    Geelong, Victoria
    I assume the globe is ok....
    Make sure there is no part of the light assembly touching anything and grounding out.
    Test the actual switch to see if it works.
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    May 2007
    Moonee Ponds
    Don't reckon it's the light. If you have central locking, unlock the door, open door does the car try to relock after 30 seconds or so ? If it does, it means your door lock module is faulty and the car doesn't know the door has been opened or open. There is a guide to repair your door lock module on Vortex do a search on there, or try the FAQ forum for mkiv's but the actual repair thread is buried somewhere there, intense though, so you may just want to purchase a new or refurbished one.
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Jun 2009
    melbourne, vic
    thanks man i do have the prob where the door is open and it locks after 30 sec, i'll have a look at vortex now cheers
    Dec 2007
    Auckland, New Zealand
    it has 2 do with the solder cracking on some sensors one of my rear passenger doors does the same thing. Need 2 take the thing apart and resolder 2 resolve the issue.
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Nov 2008
    Sydney, Macquarie Park
    Quote Originally Posted by qsilverza View Post
    that happened to me yesterday! i was inside the car and what i've found out is that when it does that you cant open the car from inside. i tried pulling the door handle - nothing, press the unlock button on the door - nothing. the only way to open it was with the key
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Jul 2009
    Renmark, SA
    Quote Originally Posted by adrian 86 View Post
    Sorry for the ignorance, I have the same problem with the drivers door, but what/where is Vortex?
    May 2007
    Moonee Ponds
    Vwvortex http://www.vwvortex.com
    http://forums.vwvortex.com/zerothread?id=1835863 - MKIV FAQ
    http://forums.vwvortex.com/zerothread?id=1542461 - Door Lock Module
    Quote Originally Posted by Jof View Post
