Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Couldn't resist
  1. #21
    Apr 2014
    Penrith, NSW
    Hate electrical problems
    RE: P1426 - Tank ventilation valve open circuit
    Solenoid stuck open? Check the connector to the purge valve on top of the charcoal cannister? You should also hear a clicking sound as it open/closes to let the fuel vapors into the intake if it is working correctly.
  2. #22
    Jul 2011
    Replace the air flow meter
  3. #23
    Why would the MAF be the problem when the issue is the car has no power over 2500 rpm because the throttle isn't opening all the way? Does the MAF stop the throttle position sensor opening?
    I had to drive to Wagga yesterday to pick up my daughter's scooter. On the way there I averaged 11.1 litres, coming back with the scooter it got 11.0 and felt slightly better to drive. Normally I'd say the long drive (7 hours) cleaned out a few things but I drive over an hour each day (and 100 ks) to get to work so there shouldn't be any stop/start gunk in the engine.
    The car was beautiful to drive despite the lack of power going up hills and having the trailer/scooter on the back made no difference to how it performed. It still slows down to 90 k's on the big hills, trailer or no trailer but doesn't get any slower and cruises at 110.
    Couldn't resist-20180819-jpg
    Next step is to check the voltage going to the accelerator and to the throttle. Might even run 5v direct to the throttle to see if that clears out some cobwebs.
    Does anyone know where I can download a wiring diagram?
    Paul
  4. #24
    Nov 2015
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  5. #25
    Looks like they charge for the service. I'm looking for something free.
  6. #26
    Apr 2014
    Penrith, NSW
    Engine code please
  7. #27
  8. #28
    Apr 2014
    Penrith, NSW
  9. #29
    Apr 2014
    Penrith, NSW
    How's that? pm me if it didn't come through
  10. #30
    It came through fine. Now I just need to work out which bit isn't getting the full 5v to the throttle position sensor.
    Thanks.
