You could be charged an easy $1500 for a clutch change. Really depends on the clutch the mechanic uses, and the labour charges for the change.
Typically, most mechanics charge around $100/hour and the typical clutch change is usually around 6-8 hours. Being a fwd makes it a little easier than an awd but it's more difficult than a rwd car so you pay a bit more labour.
My car was fitted with a Bora V5 clutch and it cost the previous owner about $500 to buy.
As for the brake fluid and coolant change. That's easy DIY. Save some cashola. However I'd expect 1-2hrs labour for s coolant change and brake fluid flush a piece.
