Sounds like classic waterpump failiure.
You should always replace when doing the timing belt. All has to come apart again now.
Call past for diagnosis and repair if you like.
mate i wouldnt even start the car, let alone drive it for an hour.
If your water pump is not working anymore, you have no coolant flow trhough the engine, which means no cooling of the engine.
If the temp goes up high enough you could bend the head, which means it has to come off, which means $2-3k to fix.
so maybe it's better to spend a few hundered on a tow truck than having the engine rebuilt
1991 BMW 318is RED E30
Update for anyone interested or in similar situation.
Tried driving down the M7 but it didn't last long without heating up so rather then risk it any further got it towed to Golf Loon.
Was indeed the water pump!
Damn you VW and having to replace every plastic piece in the car with metal.
Running well now![]()
Glad to hear you got it all sorted ... - you did well to get 11 years out of it![]()
Good that you got it towed. Im glad it all works fine now.
Just wondering, do MK4 R32s have the plastic water pump too?
