Results 1 to 10 of 18
Thread: Cooling or temperature gauge issue
    Feb 2008
    Question Cooling or temperature gauge issue
    2000 2L Golf owner of some years
    Never had a problem before with this but driving the other day the temp gauge got into the red zone and light came on.
    I pulled over, turned car off had a little look...started back up and drove off and the gauge stayed on 90 (middle). Ok for now i thought.
    But now temp gauge warms up a lot quicker then usual and with about 5 mins driving starts to get over the 90 and warning light has come on a few times. Plenty of coolant so that isn't the problem.
    Last time it did it i parked and just watched the engine. The front fans after working hard in idle suddenly went off and the gauge immediately dropped back to normal from near red. I assume if it was overheating it couldn't cool itself immediately but the temp gauge dropped immediately!?
    Seems to prefer idle over being driven.
    No other symptoms and still running the same.
    Any insights would be appreciated as not very mechanically savvy, bit wary now to drive it anywhere for fear of damaging something.
    Thanks in advance
    Dec 2008
    Sydney/Canberra
    Most likely, the water pump has failed. It's a common problem.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Nov 2006
    Largs Bay, S.A.
    Has it had the timing belt and water pump replaced previously? - generally they are done at the same time ... The plastic impeller on the stock water pump breaks after a while leading to overheating - the replacement model water pump has a metal impeller.
    Best Wishes.
    Feb 2008
    Thanks for the replies
    The timing belt was done but don't think any water pump has been replaced.
    Car is up to about 160000km.
    Any ideas on how much if this is the problem it might cost?
    Can i damage it if i keep driving in this condition?
    Last questions i promise!
    Nov 2006
    Largs Bay, S.A.
    Yes, you can damage it if you keep driving it - camshaft belt can fail as a result of stuffed water pump leading to valve damage etc.
    I'd get it checked out asap. You might want to check Recommended Repairers and Parts Suppliers
    Perhaps send Golf Loon at Camden GTI a PM to enquire about cost.
    Mar 2011
    Hey mate.
    I had the same problem with my 2002 2l GLE at 162000kms where the waterpump completely failed.
    Difference was mine litterally blew and bled all the coolant. Get it checked out incase the same thing happens to you.
    From memory my replacement pump and install was bout 500 or 600 so its not a cheap fix (on the side of the motor hard to get to)
    thermostat jammed closed?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Feb 2008
    Thanks all again
    Rolfgolf ......ok will be careful and watch the gauge closely....yes i have used GolfLoon before and been happy with his work just campbelltown is an hrs drive so would be worried car couldnt make it that distance in current state
    Zakkus.....you and the other guys i think are right as it is leaking coolant now .......i did fill it up (probably overfilled) as was down near minimum
    Dylan8 ....you overestimate my car knowledge ......will have a poke around
    Apr 2008
    Wouldn't hurt to do the timing belt again if you're replacing the water pump (make sure you get one with a metal impellor).
    2000 Mk IV GTI
    Feb 2008
    Quote Originally Posted by dubbed View Post
    Yeah would do....cheers
    Now to debate whether to limp it for an hrs drive
