Results 1 to 8 of 8
Thread: Cooling system problem HELP??
    Mar 2015
    hey everyone
    so i have a 1998 Mk4 golf 1.6 GL, my first golf! and as of last week its been over heating for some apparent reason?
    yesterday i pulled the radiator out and all the hoses and cleaned them out, some grey mud like stuff fell out but didnt seem like it was enough to stop the flow and the coolant mix didnt have much oil in it to indicate it was the HG. so i put it all back together, i noticed the thermostat was extremely stiff and definitely needed to be replaced so i did that aswell but my engine is still over heating in no more than about 10 minutes...
    Any ideas???
    Nov 2013
    Bathurst
    Had the same thing with my old 1.6 blamed everything but it ended up being the waterpump impeller. when was the timing belt done? i'd put $10 on it's that. easiest way i checked mine was pull thermostat out and stick your finger in the hole (lol) and see if you can spin the impeller. if you can then it's come apart from the actual pump and isn't moving any water.
    Pic for reference: Mine when it came out. :l
    01 MKIV GTI ME7 converted hybrid k04
    08 MKV GTI Daily driver duties
    I have serious VAG issues.
    Mar 2015
    I don't know when the belts were last done but I have a feeling you're right with the water pump being the issue so I'll check it out, thanks heaps mate!
    Feb 2015
    Central Coast NSW
    yep... I used a repco one and it blew a bearing in no time. The second has been ok.
    If your heater isnt blowing hot, or lower pipes cooler then its likely not circulating as well.
    Jul 2012
    Sinagra, Western Australia
    Pull thermostat out and stick your fingers in the hole . Can feel the water pump impellor that way.
    Mar 2015
    Fixed!!
    cheers to everyone that suggested the water-pump! i pulled it apart and the impeller had slipped off and was very weak and as soon as i grabbed it, it would just crumble in my hand. plugged in the new much stronger pump and will hopefully last me quite some time
    Attached Thumbnails Attached Thumbnails Cooling system problem HELP??-11050988_944289442256857_2021044155_n-jpg   Cooling system problem HELP??-11124418_944289435590191_1783451700_n-jpg
    Cooling system problem HELP??-11127076_944289452256856_53005500_n-jpg   Cooling system problem HELP??-11072798_944289472256854_622762680_n-jpg
    Nov 2013
    Bathurst
    Quote Originally Posted by Brandt308 View Post
    Helps when you've been through the exact same thing! Glad you got it sorted mate.
    Dec 2008
    Sydney/Canberra
    Good to hear.
    Should last you through to the next timing belt change.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
