Do you see a snow flake at the same time?
Hey guys,
When I start my MK4 GTi up [in cold weather] the coolant light flashes and I get some warning beeps. The coolant level is normal and it only happens when the car hasn't been running for several hours i.e. cold start. I take it that this isn't normal... So aside from it being a faulty sensor, anyone have any ideas as to what it might be?
I'm getting a service within the next few weeks but thought I'd see if I can get any suggestions first.
'04 BMP MkIV R32 #144
search getnew
jeeeez, i never thought it gets that cold on the eastside in the mornings...
i wouldnt get out of bed!
in regards to the original question, it depends what light comes up, could be a temp warning like the other guys have said, or a low coolant warning
i had the same problem - popped the hood, coolant looked full enough but light was still coming up
threw another splash of coolant in and it stopped, must have been just a tad too low or something, work it out....
1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
Could be a coolant level/temp sensor that is on the way out. Being a slightly older car, and being in contact with a liquid, it has probably just about given up. If you have a mate with a scan tool, they will be able to confirm this. If not, get it looked at the next time you get it serviced. Get it done sooner than later, as your ECU may be compensating for the false readings it is getting from the faulty sensor.
Nah, no snowflake symbol. I will top the coolant up and maybe give the sensor a wipe when I can be bothered!
