Results 1 to 10 of 11
Thread: Rebushing Mk4
    Dec 2009
    West End, QLD
    Rebushing Mk4
    Hi all,
    i'm about to replace every flogged out bush in the running gear of my golf 4 (1.4) I'm confused though... the OEM rear controll arm bushes - the horizontal ones) come with a bonded steel outer shel as well as an inner steel tube, the polyurethane ones i have obtained (yes they're the right part) don't have the outer... ie. they're naked - 'zat gonna be ok? or will they controll arm mount point cut them to ribbons?
    cheers,
    mix
    Jun 2008
    Ringwood, Victoria
    You will need to cut the rubber away from the aluminium outer of you old bushes and fit the urethane inside them. Then after a few months you will have to pull out the urethane and replace them again.
    Urethane generally doesn't work so well in this application because it has little to no memory, unlike the bonded rubber. Urethane works well where there is no rotational moment applied to it under load, hence why alot of people (myself included) stick with the heavy duty OE R32/Audi TT rear bushes and only put urethane in the front bush of the LCA, where the only movement is a pivot in the sleeve of the bush.
    Nov 2009
    Melbourne, Victoria
    I replaced the same part 3 weeks ago to obtain a roadworthy. I got the part from a place here in Melbourne at $22 each and they are the original ones as described with the inner and outer metal + rubber inbetween. Let me know if you'd like the details and I can pass them on to you.
    Canberra
    As gavs pointed out, stay away from urethane for the rear bushes, the best option is the TT/R32 solid rubber bushes for the front one you can use new stock ones or urethane.
    http://www.ecstuning.com/Volkswagen-...shings/ES3893/
    Snowy
    Townsvegas QLD
    DO they look like this? If so this is an extra new set I have throw me an offer cheers J
    SLAM.POKE.TUCK.DROP.DOPE!
    Dec 2009
    West End, QLD
    thanks everyone,
    didn't know that about poly bushes - but i don't imagine thate'd be much tortional force in the rear ctrl. arm bush - mostly lateral no? anyway - the ones in there (rubber OEM) are fairly new. I had them replaced not so long ago -
    it has just ocurred to me that my tie-rod ends are probably also shot.
    thanks for the link! heaps of stuff there.
    mix.
    Apr 2008
    Is there a definitive guide on the best bushes to use all around on the MkIV?
    2000 Mk IV GTI
    [QUOTE=gavs;426004]You will need to cut the rubber away from the aluminium outer of you old bushes and fit the urethane inside them. Then after a few months you will have to pull out the urethane and replace them again./QUOTE]
    Need to correct the first statement about fitting the urethane inside the old outer sleeve, you'd never be able to do that. Cut the rubber out so you can get a hacksaw in to split the outer of the bush. It'll knock out easy then.
    I ran urethane in loads of cars, it's not as good as the TT/S3 bushes for sure. They weren't available back in the day.
    TT/S3 is the way to go.
    Jun 2008
    Ringwood, Victoria
    Thanks for the clarification Gavin, though I have seen on a website (might be superpro though I can't be certain...) where they say to cut out the rubber and leave the aluminium carrier ring in place, then press the urethane into the aluminium ring.... Unless I'm imagining it, which is highly probable!!!
    Dubbed, there is a guide, not sure if it's here or on Vortex and it outlines the options and proposes the best setup.
    Most of the forces that your rear control arm bush is subjected to is a twisting up and down motion. That said, the whole idea of a bush is to provide a semi-flexible joint so it realistically moves around in all directions in all different conditions. If you can, jack up your car and take off a front wheel. You will be able to see what kind of load that your bushes go through with a full wheel extension.
    Dec 2007
    Brisbane, Southside...
    I know that once the Urethane bushes that came with my adjustable control arms are shagged I'll be going back to the solid rubber ones. I don't know if it's just a myth that's been perpetuated but the problems outlined above have put me off.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
