Results 1 to 8 of 8
Thread: Coolant for my R32
    Nov 2008
    Northern Sydney
    Coolant for my R32
    So this morning i was greeted by the Stop light on my dash with Low Coolant showing. Ergh. Walk to the station time.
    In the past i have just used whatever green coolant i could find as i had cars i didn't care about nearly as much as the R. Now in the manual it says to use the VW stuff (the red stuff). I am guessing this is advisable but wanted to check whether it was any different or just a money making scam by VW.
    The next thing is finding out where it has gone to. Haven't checked the coolant level in a few weeks but last check it was full so worried a hose may have gone or something. Any usual suspects here?
    2010 Skoda Octavia vRS Wagon
    Jul 2007
    Brissy
    There are plenty of places for the coolant to leak from.
    I had a few leaks where the hoses had shrunk somewhat.
    You might spot the leak by looking for pinkish powder (dry coolant)
    Get the coolant in the book (G12), normal coolant does not mix well. Water alone will not provide enough lubricant for water pump internals.
    Nov 2008
    Northern Sydney
    cheers. Will grab some coolant today if possible.
    Aug 2009
    VIC
    I personally would only use the recommended G12 coolant. It is pricey from the dealer at i think $25 per 1.5L bottle. You will need two bottles if your doing a full top up. If anyone could clarify as to whether G12 is the ONLY recommended way to go this would be good.
    Apr 2008
    The coolant recommendation is one worth following. It has a different chemical makeup to the standard green stuff.
    Pop your oil cap and make us all happy by telling us there's no white foam underneath it...
    Nothing to see here...
    Nov 2008
    Northern Sydney
    Quote Originally Posted by Manaz View Post
    Don't say things like that...got me worried now!
    Apr 2008
    Quote Originally Posted by sir_camel View Post
    So check it and we'll all be happy when your oil's clean!
    Nov 2008
    Northern Sydney
    Checked this morn and all looked ok. Topped her up but just had the station run so will take it for a proper dtrive tonight to see if it holds it's coolant level.
