Results 1 to 8 of 8
Thread: Connecting Fog Lights to High Beam
    Jun 2008
    Sydney, The Hills
    Ok so my fog lights are ridiculously bright and i have wired them up to my euro switch on the 'pull' switch, which is for the fog lights in the head lights. But as they are so damn bright i want to wire them up to my high beam as well, to actually make use of this light. I couldn't find anything useful on Vortex.
    I know i need to run a power wire from the fog wire that runs into my euro switch to the power wire for the high beams, but as the switch for high beams is the stalk on the steering column, i thought running a power wire up to it might be a tad difficult. I was wondering if anyone else has done anything like this?
    Cheers, Evan.
    Jan 2009
    Anglesea,victoria
    As far as i know its illegal to drive with your fog lights on in conditions that arn't foggy.
    May 2007
    Moonee Ponds
    HEHE ! I would just turn the fogs on when the brights are on. That's what I do when I need the extra vis.
    Quote Originally Posted by Mitchy G View Post
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Jun 2008
    Sydney, The Hills
    Yer thats why i dont use them, they are too bright. Only want them on when high beams are on. soooooooooo many ppl drive around with them on tho, the cops msnt be tooo strict on that one.
    Quote Originally Posted by qsilverza View Post
    Yer that gets abit annoying tho, a car comes along and you have to wack to switches on both sides of the steering wheel to turn off both lights
    Dec 2007
    Brisbane, Southside...
    Just play with the alignment on them. Aligned properly, driving/fog lights shouldn't cause issues to anyone on a normal sedan (4WDs with them on bullbars etc is another kettle of fish).
    The authorities can't seem to get this through their thick heads and would rather penalise everyone rather than the stupid car makers (yes you especially Holden) and the idiots who install them aftermarket and don't get them aligned properly.
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jul 2005
    shouldn't need to go into the steering column wiring for this one.
    do you want to only operate the fogs when high beams are on or from either the fog light switch or high beam switch?
    if you only want to operate them off the high beam then connect into the high beam lamp from the back of the headlamp assembly and loop into the fog lights. or find the relay that operates the high beam and connect into the output of this to the fogs.
    the other option will be more difficult as you will need to prevent the high beams from operating off the fog light switch since you will essentially have power to the fogs from two different sources.. not an electronics wiz here but dont think diodes will handle the current of the fog lights so dont think it will be as simple as putting these in.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Albury, NSW Australia
    Legally, fog lights should be wired to work on low-beam or parking lights only.
    Driving lights are meant to work only on high beam.
    And, as above, you should only use them when conditions call for them - and not be a giant douche and use them all the time.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Mar 2009
    I have the exact same issue here mate! Bought some aftermarket fog lights and installed with the help of my uncle; and its honestly like having a second high beam! I mean it's good, but really don't get a chance to use then as it's too much of a hassle to click them on/off when approaching another car...So they don't really get used; they are mostly for aesthetic purposes now...
    When installing them we had them wired to (i think) the ignition so that they can only run with the car on acc; what about wiring them to only run with high beam, then leaving them switched on constantly? So that they cut out when high beam is switched off. (Sorry if that's already exactly what you meant haha)
    I might have a go with my uncle later this week; will post any breakthroughs!
    Whats funny about my fog lights being so bright (assuming yours are the same!) is that if a cop did pull you over and was being a right ; he'd mark you for a) driving with fog lights on unnecessarily and b) using high beam inappropriately without it even being on haha
