Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: Coilovers
  1. #41
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by Lonewolf1983 View Post
    v3's offer bump and rebound adjustability
    how's that different from damper adjustability ? so you mean that you can set the damper to stiff and still have comfortable ride ? sorry for the noob question ..
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
  2. #42
    May 2010
    Perth
    Quote Originally Posted by Golf-Sam View Post
    its the 2 forms of damper adjusting (the up and down strokes essentially).
    In general, yes it allows you to soften the ride or stiffen it to an extent
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
  3. #43
    Jun 2006
    Orange NSW
    "damper adjustability" is the same thing. It's just a bit of an over-simplification.
    Some dampers, like the Bilstein, only allow one single adjustment. When you adjust the valving, you are softening or firming both the bump (compression, wheel goes up) and rebound (extension, wheel goes down) at the same time.
    With the KW V3, you can adjust the two independently, via 2 separate valves.
  4. #44
    Jul 2010
    Canberra , ACT
    love it ! thanks for the info .. better save up
