Results 1 to 2 of 2
Thread: Coil Packs keep failing?
    Jan 2013
    Queensland
    In the last year, I've had 4 coil packs go on my BDE V6 Bora.
    The rocker cover gasket was leaking and oil was getting into the spark plug wells, so I had that along with the plug seals replaced, but still have coil packs die on different cylinders.
    Any thoughts on what the culprit could be? Faulty leads/harness?
    VW didn't thoroughly clean out the plug wells when they replaced the rocker cover gasket, so there is still some dried residue left over on the walls and a little bit where the spark plug seats... maybe this could be it? I'll be speaking with them to get the situation rectified as it really should have been cleaned out when the had the cover removed.
    Dec 2007
    Melburg East VIC
    it's recommended that all coil packs are replaced at the same time, not just the ones that fail
    not familiar with V6 boras but check if you have a ignition amp/output stage on your airbox?
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
