Results 1 to 7 of 7
Thread: Coil-overs for 4-Motion Bora
    Mar 2009
    Wagga Wagga
    Have been offered a set of KW V3 Coilovers off a R32.
    Whats everyones thoughts on these coilovers?
    Suggestions?
    Apr 2008
    Quote Originally Posted by trickysimon View Post
    Suggestions?
    They have a great reputation - they were more than I wanted to pay when I got my Bilstein PSS9s, otherwise I'd probably have gone that way.
    Just make sure they're in good condition. It may be worthwhile having the Australian distributor (East Coast Suspensions) give them a once-over before fitting.
    Nothing to see here...
    May 2010
    Perth
    I have the Var1's and they're very good
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Apr 2008
    Quote Originally Posted by Lonewolf1983 View Post
    The V1s have adjustable height only.
    V2s have adjustable height and rebound.
    V3s have adjustable height, rebound and compression.
    So V3s give the most tunability (with the most complexity).
    May 2010
    Perth
    Correct, and the Var1's are very good
    Mar 2009
    Wagga Wagga
    Thanks for the info guys
    Jan 2008
    Canning Vale, Perth, WA
    unless you are planning on tracking the car, they are quite probably overkill.
    However, if you are getting a bargain, then go for it!!
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
