Results 1 to 5 of 5
Thread: Clutching solutions
    BLKMJC Guest
    PM or email bug racer, he posts on this forum.
    I would go for a ECS Stage 1 kit which includes light flywheel and is pretty cheap. But its only rated for about 270hp.
    What I would definately do is get a Pelquin LSD... before you get a clutch or at the same time
    BLKMJC
    Dec 2006
    Quote Originally Posted by BLKMJC
    BLKMJC
    I believe bug racer is quite the "busy" person from his posts previously - I'll send him and email and call him in the morning to see what kind of pricing he can offer.
    ECS Stage 2 Clutch Kit (228mm) With ECS 14lbs Flywheel, 275-330hp looks like it will cater to my needs/power range... worst come to worst I'll airfreight it.
    LSD not really required as I value first and second and treat them accordingly.....
    -DIDZ
    BLKMJC Guest
    Yes I think he has been pretty busy lately, but one of the best guys to speak to in the country about this.
    Mine only has about 260hp and I blew the gearbox/diff.. and I value my 1st and 2nd too. It actually let go in 5th but yes who knows when the damaged occured. Either way if you gove above 200hp get the LSD... unless you want to buy a new box. Pay to play
    BLKMJC
    gpk_gti Guest
    Derek at European Autotech Pty Limited
    4 Polo Avenue, Unit 5
    Mona Vale
    NSW 2103
    tel: +61 2 9979.4484
    fax: +61 2 9979.4384
    http://www.europeanautotech.com.au
    email: derek@europeanautotech.com.au
    you should also contact the guy that built the car(the guy you were telling me about) and you should also give Derek a call.heard alot of good things about him.
Similar Threads
  1. Slipping Belts - miracle solutions
    By Tameth_au in forum Mk2 Golf & Jetta
    Last Post: 05-11-2005, 10:26 AM
