Results 1 to 9 of 9
Thread: Clutch and thrust bearing question
    Nov 2013
    So i replaced my clutch with an ECS Stage 1 kit this weekend. While installing the new thrust bearing into the clutch fork the plastic clip broke off the back of the bearing (fail), so in a panic i just put the old thrust bearing back in. It had all the same dimensions and was in good condition.
    Now once the engine has warmed up i have a bit of a rattle sound when giving the engine a bit of a rev. When i press the clutch though it disappears. I was just wondering, is the thrust bearing always in contact with the pressure plate fins, thus always rotating? or is there supposed to be a spring or something of sorts pulling the clutch fork away from the pressure plate?
    Gold Coast
    if you press the clutch and the sound goes im afraid its going to be the thrust bearing...what is the vehicle ?
    Mine makes a hideous noise at idle. I consider it normal. Usually worse if the ac is running.
    Nov 2013
    It's a 99 golf gti, why would it chatter with no load on it?
    Quote Originally Posted by danegti View Post
    They just do, some worse than others. The bearing in mine was less than 4 months old, minimal KMs. Blew the motor and rebuilt with a stage 3 clutch. Reused the bearing and it sounds rough as.
    Too big a job to pull the box just to do the bearing.
    AC increases the load on the engine, same as when the fans kick in. The alternator is working harder and that means the ECU regulates the idle to stop it stalling.
    Jul 2007
    Brissy
    Did you replace the flywheel ?
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jan 2011
    Gold Coast, QLD
    What weight is the flywheel? Anything less than 20lbs you will have chatter. The lighter you go the louder it gets.
    Nov 2013
    Yeh I replaced the clutch because the previous dmf had had it. I got the 14lb one
    Jul 2007
    Brissy
    The Single mass flywheel is known to cause noise, they put in a dual mass for a reason. So now you have some more character
    MK4 GTI - Sold
