Results 1 to 7 of 7
Thread: Clutch problems
    Clutch problems
    Hey. I have a 1999 mk4 golf 1.8 20v
    Recently when I started my car in neutral and tried putting the car in gear it wouldn't go in. I started the car in gear and it jumped forward. I worked out that it only happens every now and then. I'm not sure if what I'm doing is helping but I pump the clutch a bit (car off) and try again. Eventually it works perfect. And no issues until I start the car some other time. But I haven't not been able to get it working yet. I always seem to eventually get it to work
    Any ideas on what the problem could be?
    Ps I have recently replaced the slave with oem replacement
    Thanks
    Jul 2007
    Brissy
    I would guess its the master or slave cylinder.
    A simple test for the clutch is to get into a high gear like 4th or 5th and drive up a hill. If the revs rise quickly but the speed does not then the clutch is slipping and needs replacement.
    Who replaced the slave cylinder ? Why was it done - what were the symptoms ?
    I have a problem that my mechanic says is the master cylinder, if I change from 1st to 2nd at high engine speed the gear crunches like the clutch is not engaged. It is most annoying. But the clutch itself is fine.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    The slave was leaking. So I replaced it. I think ur right it will be the master. Clutch never seems to slip either
    Thanks
    Sep 2008
    Townsville
    The clutch will only slip if the clutch plate or pressure plate is stuffed not the release system . I replaced a slave as you could feel the clutch "bleed" off if you held your foot on the peddle for a while and long story short it was the line from the master to the slave that was leaking near the slave end so just check your fluid level n take a look around the slave as the gear box dose a good job of catching leaking fluid.
    Could also be a poor job of bleeding the system after the slave was replaced ? get yourself a power bleeder and you cant go wrong.
    May 2010
    Quote Originally Posted by jacob View Post
    Thanks
    x2 on master.
    Quote Originally Posted by JustCruisn View Post
    Wouldn't that be the syncro?
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Jul 2007
    Brissy
    Quote Originally Posted by Speed View Post
    I pray that it is not
    MK4 GTI - Sold
    Jul 2007
    Brissy
    Since the spammers bought this thread back up. I though I'd add that the shifting problems I had. It was down to gearbox oil. I replaced with some redline and it is smooth as silk.
    MK4 GTI - Sold
