Put it this way. When another R32 owner out there (not a member here) heard that I was still on the stock clutch at 100,000kms I was told I wasn't driving it hard enough. :p
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Mine is quite low down. the slave and master plus all clutch accesories were replaced at 72,000 KM for a different problem which turned out to be the pressure plate.
If you want to test the clutch try in sixth gear at about 50 - 60 see if she slips up or rev's.
Audi B4 80 Q V6 '94 Race Car !! KEGGED
Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo '01 Gone
Pickup point was in almost the same position! After the clutch was replaced pickup point was about...10mm up.
You serious dude? That sounds pretty ridiculous to me. Clutch change has always been about 1000 from what I've heard, have you asked them to get parts from places that sell them at realistic prices? That could be part of your problem..cos that does sound expensive to me.
Sounds like Clutch kit reqd mate. The high bite can be low linings on the plate. It would be a safe bet to replace the kit mind you as the pressure plate can also have an issue as previously mentioned and correct. Thats really it, now ive done a few clutches on the Pogs at pretty low Kss , once they got woken up by a software upgrade then the demands on everything that was before quite happy are somewhat changed. Changed a kit on a Pog that had around 30k and it was slipping like mad during logs post flash. Off topic slightly had a bloke at work just got an upgrade to his Falcon turbo. Now before hand i warned him of the things that can show up once you ask more of the machine and yeah 1 fuel pump, 1 coil pack and now a new Auto trans reqd.,
Dont be disheartened mate you will be happy when she is fixed.
Jmac
Alba European
I don't think it should be that expensive man, check places like GAP, GSF, Tooleys, ASV, ring people like golf loon, seb, even jmac...most people on here that are mechanics can get good prices for things. I'd be surprised if it cost you that much through any of those I mentioned!
[QUOTE=Mrk_Mickey;340293]I don't think it should be that expensive man, check places like GAP, GSF, Tooleys, ASV, ring people like golf loon, seb, even jmac...most people on here that are mechanics can get good prices for things. I'd be surprised if it cost you that much through any of those I mentioned![/QUOTE
Too true Mickey. Let me have a stab, wont know till Monday though and yeah like you say feel free to call
cheers
Jmac
Alba European
Got the clutch done today. The starter was OK once it was cleared of clucth dust.
Here is the break down.
$1363.64 for the clutch kit (flywheel clutch pressure plate)
$75.15 Release bearing
$55.90 Clutch lever
$3.40 Spring retainer Fork
$14.90 Ball pin
$82.50 throw out support
$109.09 Rear Main housing
$12.50 Brakleen ( I dunno what that is)
$1717.08 All clutch bits
$614.25 - Labour including a service
Anything here look too expensive ?
