Results 1 to 10 of 12
Thread: Clutch peddle issues
    Sep 2008
    Launceston
    Well at the traffic lights today i had the joy of my clutch mechanism breaking and my peddle dropping to the floor.
    After being push through the lights i found that the previous owner was kind enough not to leave the removable towing eye for me .....ahhhh good times.
    I think i will just get a mate to weld the broken piece of metal back on a get a new plastic clip from vw.
    How hard a job is it to get the clutch peddle off and back on again?
    Nick
    Feb 2008
    nsw
    its not too bad you will need to use cable ties to hold the spring down/compressed to make it easyer to get back in. its not too hard a new pedal is only like 60 or so $$$ from vw any ways.
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    I know exactly how you feel as it happened to my Bora just recently. I took it to VW Barloworld in Five Dock to fix and they charged me about $500 to get it fixed! They reckoned I had bent the shaft going into the Master Cylinder when the preddle collapsed so they had to straighten it. They also said it was quite a time intensive job to remove the clutch peddle to replace the bush and peddle. Most of the charge was in labour.
    I would love to know if it was infact a simple job and they just ripped me off. I'm not sure I'd have any legal recourse if that is the case, but I did feel I might be being taken for a ride with it all.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Feb 2008
    nsw
    took me at home about 1.5 hours to do and i just gave it a stab, never done one before. yep you got ripeed
    Sep 2008
    Launceston
    Is it best to put the cable ties on the spring when the peddle is all the way down or when you pull it back up?
    Thanks for your help MIS.18T.
    May 2007
    Moonee Ponds
    Mine collpased to the floor after a myriad of problems. Dean at Volkspower fixed mine for me, he did it for a Very good price.
    So I would suggest you got totally ripped dude.
    Quote Originally Posted by Arctra View Post
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    did they replace the clutch master at that price?
    same thing happened to me, and i believe that its actually better to reweld the metal tab back on as it ends up stronger than a new one...
    heres a link to my thread when i had the same issue... go to page 3...
    http://www.vwwatercooled.org.au/newf...t=18738&page=3
    i however was lazy and didnt have easy acess to a welder so i just replaced mine with a new one...
    if you buy the pedal, it comes with the white plastic clip which fits onto the master...
    yes it is a fiddly job, but not $500 worth!
    cheers, dan
    edit: added link
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    Sep 2008
    Launceston
    I have order the parts from VW today so will hopefully be able to get into it over the next few days. I am not sure of the actual VW part numbers but the parts you need are #10 & #7 from the dealers drawings.
    Aug 2007
    I would also suggest they run a weld on the new pedal, i have with the last couple ive done, the tacks Vw put on the pedal are quite dung and dont last, and when all the other variables get added like heavy pressure plate etc the life of the pedal reduces
    Jmac
    Alba European
    Sep 2008
    Launceston
    By the time i got home after work it was already dark so i had to undertake this lovely job with the use of a 12v light.
    For anyone who is doing this for the first time, i thought i would write down a couple of points i learnt along the way.
    All you will need is a cable tie, a pair of pliers, 13mm socket, and a 13mm ring spanner or shifter.
    - First of all, do it in the daylight.
    - Like JMAC said, tack some extra welds on your new pedel or repair the old one. This way you shouldn't have to play around with it again.
    - After you have pulled the peddle out compress the clutch spring with your hands and use one cable tie to hold it. Put the cable tie in a spot you will be able to snip with some pliers when it is back in location.
    - Make sure you put the white plastic piece back on the shaft that connects to the master cylinder before you put the peddle back in.
    If i had known these few point i probably could have had this job wrapped up in 30mins.
    Nick
